I’d like to renovate an entire room that’s off our living room. This room used to be a screened-in porch under a second story deck. House was built around 1978-1980, not sure if the deck was built then or later. At some point, one of the owners enclosed the porch and the deck into rooms of the house. As we discovered when having our roof and siding redone, they did not do this very well. Deck structure is still in there, parts weren't attached to house correctly, and even some of the screen walls were under the drywall (?!?!).
Been going back and forth about whether I should just take it down to the studs, then see what we have, or have someone inspect it first (if they can). I’m guessing I probably need a permit, but I’m worried that the inspection will find more problems than we know about. If I’m not altering the actual structure of the room, just redoing drywall and insulation, would I need a permit/inspection? If I do tear everything down, and then an inspector says it’s all wrong, how would I even go about fixing everything? And would I be required to? Is there any provision that previous work done by another owner can be allowed, since it wasn’t found before (pretty sure there were no permits pulled previously)? My nightmare scenario is I get the walls open, then the inspector says the whole back portion needs to be ripped off and rebuilt.
Thanks!
Thanks!
