Hi,
It's heating up here in TX and I have doubts that my and my tenant's AC are going to be able to keep up. It's a side by side single story duplex. Since last year I installed new condensers, eave vents, and shot Lomit II radiant barrier over the complete surfaces of the roof sheathing and the upper trusses. I'm still not overly confident though because of the complete sun exposure I get here, and the modest size of the AC systems (2 ton).
So I'm thinking about adding to the insulation which is currently up there. What is there is blown cellulose which has compressed down over 20 years to about 3". I'm considering blown fiberglass which I'm told is very efficient and less itchy to work with than pink.
That all said, here's my problem, or what I think may be a problem. My rafters are 24 on center. I already have noticed that many of my ceiling drywall panels are bowing a bit in the center from lack of support. To get much benefit from this job I'd need to blow an additional 8-12" of this stuff, and I'm worried about how that will affect the ceiling long term.
I've considered nailing in 2x4 studs between the rafters in the center of each panel so that I can drop a few extra drywall screws to give them all added support. Although I'm handy enough to do all of this, I'm a no nothing when it comes to design and construction. I'd like to ask the experts whether this is a bad idea? Are the joints designed such that they simply aren't meant to be connected to each other in this manner?
Also, does what I'm contemplating even make sense from a practical perspective? On my side of the property it wouldn't be terribly hard because I'm in the process of scraping off the old popcorn and it won't add much work to add the necessary screws. However my tentant's side already had the ceiling scraped and textured, so it will result in days of touch up and painting.
Am I being too paranoid about this?
Thanks for the thoughts!
Eric
Eric
