Hi Everyone. First time here. I have a quick question.
Our roof had to be replaced. So I decided to add a little dormer on one side of the room for extra space in the house. Got a contractor who fit the bill, had good reviews etc... Just the other day they started construction. We had agreed on soffit vents from below (excuse my poor knowledge of roofing terms) and a ridge vent above.
During construction I talked to the guys doing the job and they told me they were just venting the dormer. I'll make a long story short, after much back and forth I ended up with a few box vents on the opposite side of the dormer but no soffit vents. They told me that they don't like putting a ridge vent in as it may leak back in on the part where the low sloped dormer roof is. I kind of get that... I was told by others that they could have done a one sided ridge vent though.
I finally talked them into installing soffit vents (that's in our contract anyway) and it doesn't seem to make much sense to have any type of venting on top of the roof if there is no place for air to enter below. Or am I wrong?
The box vents up top don't really match up with anything in the attic and seem kind of low to me. What they are telling me to do now is that when I install the drywall, to leave a little box underneath the ridge of the roof so that the air can flow under the ridge and then exhaust through the box vents on the other side.
My question is, is this legit? Will those box vents be enough to exhaust all the air? Seeing that they are not on top of the roof but a 1-2 feet below the ridge, will they still be able to pull all the hot air out? I am in Ohio, where it gets hot and cold, will the box vents in the winter also take the cold air and moisture out?
Any input is appreciated, I just don't know anything about all this, and I sort of halted the construction at this point because I'm not sure if they are just trying to find a cheap way on doing this or if this would be an acceptable way of venting the roof.
Thanks so much for any ideas and input!
Mike
Edit:
I included a few pictures of the inside and outside. On the inside you can see the box vents are somewhat low and randomly spaced, I made a red line showing how they told me to build the drywall ceiling for that room so that air can vent from one side to another. Also a few pictures from the outside.
Mike
Edit:
