1 - 8 of 8 Posts
Hello. My attic is a pretty typical attic. There is a flat 4 foot wide space down the middle and off of both sides extends diagonal 2x4's that are on I would guess a 40 degree angle to the roof joists.
Basically, I want to know if it's bad to remove one of these supports so I can have an opening through the diagonal 2x4's in order to store boxes under the rows of 2x4's? I want to put down some plywood under the diagonal 2x4's to create some more storage space. I just need an access point to get through them.
Will removing one of these diagonal 2x4's compromise the integrity of the structure?
thanks for reading. I hope that made sense.
So, based on this pictures is it safe to say that it would not be ok to remove one of these supports?
I was thinking of even cutting the top one and putting a cross piece 2x4 above the entrance to the storage area.
So, yah or nay?
Your Roof will definetely sag if 1 is removed.
This roof is hand framed & there is an option.
If you take 1 out, don't go all the way to the rafter.
Put in a double 2x6 on the diagonal as you would when installing a header for a door or window.
This shoud be enough but you could install cripples on both sides as well
Dale Chomechko
DC Roofing Inc
DCL Contracting Inc
1 - 8 of 8 Posts
