1 - 6 of 6 Posts
· Registered User
Which way do the rafters/trusses run?
2x4's wouldn't work if 16' span, or 8' under UBC.
(only span 7'10" IRC, 0 for UBC-- require 2x6 min. even 12"o.c.)
And that's with no snow load.
Be safe, G
· Registered User
"16' A frame/2 = 8' span - 8" walls = 7' 4" actual span ??" Span of rafter is measured from outside wall to center line. 16'/2 = 8' 8'. The only time to measure from something is (UBC 2320.12.7)Rafter span can be measured from purlin support Under IRC, 2x4 spans 7'10", not 8'. Under UBC, can not use any 2x4's for rafters. Hence, I gave two codes, as I don't know which one his local jurisdiction is under.
Be safe, G
1 - 6 of 6 Posts
