1 - 9 of 9 Posts
I am building a roof over a deck that is on the main level of a house with a walk out basement. I'm using double 2 X 10's as the support beams for the roof rafters. I'm not using trusses so I will be doing a stick built roof using 2 x 6 rafters and a double 2 x 10 for the roof ridge support. The front support beam is resting on 6 x 6 posts on each corner which is a 20 feet span.
My question is whether this is too much of a span for the double 2 x 10's without any support in the middle
I forgot to add that I'm in Illinois.
· retired framer
Yeah, that is to far, I would think a 20ft beam holding up a ridge beam would be getting big. I think that might be why you see the gable timber frame truss is often used for that.
Thank you to the person that responded. I'm not sure of how to fix it at this point. I have another question. Does it matter if only one of the double 2 X 10's is fully sitting on the 6 x 6 post? The other one has only about 1" sitting fully on the post.
· retired framer
It's always best to have full support sounds like you will have 2 1/2" of bearing. That might have a chance of passing. Do you have a reason for that?
Thanks again. I have rectified the problem by cutting back on the 6 x 6 to where the double 2 x 10's are fully resting on the posts. I also glued and screwed 1/2" plywood between the double 2 x 10's for extra support of the 20' span. I hope this is all sufficient.
· retired framer
I don't like it. A double 2x10 will sag under it's own weight and now you have plywood that will stop it from sagging in 8 ft chunks.
If allowed to sag you would see it, but the early warning you get maybe just as it breaks.
I have a similar case so I called Weyerhauser (beam manufacturer which supplies my local lumber yard). Was on the phone for 10 minutes and the tech gave me 2 sizing options for beams and he emailed the specs to me. I submitted to my township for permit approval and they accepted them.
The number for Weyerhauser is 888 453 8358
· JUSTA MEMBER
A better alternative would have been to use triple 2X as your beam, and cut the 6X6 off flush, no notch.
Then make sure the 3 2Xs are all "crown up".
That way they are less prone to sag and fail.
ED
1 - 9 of 9 Posts
