Hi,
I am planning to install TV antenna in my attic.
In doing so, I started to inspect my attic which have one of the heat-pump unit in it. I noticed the roof frame/truss configuration and started to plan where I should mount the antenna and feed the coax cable.
In doing so, I start to ponder if I crawl around these roof and stepping on the frame/truss, would there be the roof frame/truss weak spot where I should NOT step on? :confused1: I don't want to break anything.
Thank you!
Nick
Attached is the roof frame/truss of my house.
Framing Contractor
Gemerally, walking on any part of the bottom chord should be ok. If you can bring up some strips of plywood, you could span over a few trusses and make things even nicer. Usually, the weak spot is when you misstep and land on the ceiling material.
There should not be any "weak" spots. For your own safety it would be a good idea to lay a piece of plywood or OSB down to stand on. If you happen to slip off the truss cord you'll go through the sheetrock.
I just want to mention that while I stated the type of roof truss, I am not sure if it is the exact type. My house was built in 2004.
Do you know if any roof truss type do not have any weak point?
