I'm working on renovating a basement room and trying to find an answer for this.
Scenario is standard 2x4 walls that will be cavity filled with 2lb spray foam. While technically the foam can be sprayed directly on the wires (though the device boxes have to be sealed to keep foam out) I REALLY would prefer to have them in conduit. That said, can I have 2 pieces of NMD90 14/2 in a 3/4" piece of EMT (about 6' total length) to keep the foam off of it? (1 down to the box, other up to run to the next box.)
And yes, the work will all be inspected (have the building permit already and will have an electrician double check my work and have the ESA out to inspect), just trying to keep labour costs down.
