Hello i am preparing to insulate my rim joists. I wanted to use spray foam and fill the entire joist that hangs over the outside of the house. I hear and seen people just use 2" foam board and close it off when it meets the bsmt walls. Is that the same as spray foam? I know it would be cheaper then it but it is more efficient with insulation and also keeping bugs out from comming in via the outside ply being shot to sh*t. Thats my next questiom can i also install a 2inch foam board on the outside of the rimjoist and spray around it to seal up any gaps? My joist hang over about two ft over the foundation so thats what im trying to clear. Any help would bw great thanks in advance.
Sent from my SM-G900V using Tapatalk
