I need extra insulation in my attic which is a cold space, I was thinking of putting down the rigid foam on the floor surfaces and screwing it into the sub floor to help boost the insulation. Does anyone know if this is a good option..
+1 with WOW...go with a blow-in or batt. product and you can cover it all with a tyvek like material (class III vapor retarder MAX.) to help mitigate air movement through the fibers. It is cheaper too!
Registered User
1. Where are you located?
2. Is there HVAC in the attic?
3. Do you plan on storing household goods up there?
Gary
