1 - 15 of 15 Posts
I plan on putting rigid foam on basement walls. Live in NJ. Any difference between Owens Corn Foamular vs Dow Styrofoam? Plan on using 2inch. Only difference I see is price and color and brand. Anything I am missing? Thanks
· Registered User
One absorbs 3 times water, what type of OC? One retains 96% R-value, another 98%..
Gary
· Registered User
For that big of a price difference, figure them equal. The water absorption test is less with OCorn. = 0.10 and Dow= 0.30... not a biggie considering water vapor will keep the board saturated most the year anyway, lol. They used to be the same company till one branched off. Be sure to use a closed grid glue pattern on the concrete, to reduce any air leaks inadvertently made when installing it. Add some 1/2" EXP under the frame wall bottom plate for a thermal/air/capillary break. Air-seal the rim joists with canned foam using extra 2". Use a latex based paint on the drywall. Pictures when done... we love pictures!
Gary
Reactions: echonewyork
· Registered User
I'd use canned foam or furnace duct mastic/mesh tape for total air-seal. The c. foam is more flexible, or use some quality caulking or better still; acoustical sealant (best); http://www.liquidnails.com/products/acoustical-sealant-AS825 under the overlap that can give-some with slight movement. The foam boards shrink over time (aging); http://www.buildingscience.com/documents/published-articles/pa-foam-shrinks Just like a rim joist, it's the air leak that will give up the moisture in condensation; http://www.buildingscience.com/docu...joist/files/bscinfo_408_critical_seal_rev.pdf Of coarse on a wall, the air is going from inside to wall, not both ways as in rim. ADA the drywall to stop air at the first line of defense; http://www.buildingscience.com/documents/information-sheets/air-barriers-airtight-drywall-approach/
Gary
PS. after that, I just HAD to use more links, lol.
1 - 15 of 15 Posts
