1 - 8 of 8 Posts
Here is a problem. I am trying to run 2 1/2" rigid conduit in a wet area to a 2 1/2" threaded hub.
What would be the best way to connect up the box with rigid?
Inspector/Instructor
Seriously are you talking about installing a riser? More info is need to understand what your trying to accomplish.:yes:
Master Electrician
Thread the hub onto the pipe then connect the hub to the can. In most cases you really shouldn't need a threaded hub if you are entering the box from below.
1 - 8 of 8 Posts
