I have a Pheem water heater installed exactly 8 years ago and now the pilot light went out. below are the steps I took.
- relit the poilt light - it went out again
- tried to relight and it would not light
- installed new Thermo couple
- Pilot light relit and worked fine
- moved the thermostat to warm, gas kicked in and ignited to heat the water
- after 10 seconds, the flame went out as we as the pilot light
- pilot light would not relight
- pulled everyhting apart and put it all back together, pilot light worked fine, flame kicked in and started to heat the water, after 10 seconds it went out again.
- Seems that the only way to reignite the pilot light is to take everyhting apart, put it all back together and it works for 10 seconds, then it goes out and nothing.
Any ideas as to what could be going on? Should I buy a new gas valve?
Thanks for any help,
Chuck
Chuck
