1 - 2 of 2 Posts
Hi
Having a problem with my Reznor XA-150 hanging garage heater.
It goes on fine on the first cycle - pilot lights (no problem, new thermocouple 2 yrs ago), main burner lights fine, delay before fan comes on (normal, I understand) and heater runs for a while. BUT, after a while the fan stops and the main burner keeps going and gets quite hot. Then the fan will start switching on and off intermittently, anywhere from 2 seconds to 30 seconds.
I believe it's either the limit control or the fan control, but I'm not sure of the theory of operation and want to test before buying a part. I have a schematic if that helps.
Thanks in advance for your thoughts,
Joe
PS replaced the fan motor cap as well a while ago, motor runs well. Am currently jumping the motor directly to AC in, leaving it on all the time.
Administrator
Check if the fan control is sending voltage when the fan stops.
1 - 2 of 2 Posts
