Hello!
Just purchased our first home, which has had an upgrade a few decades ago, but it's time to put in 3 conductor to all the outlets, swap out old outlets for tamper resistant/GFCI outlets, etc etc. I have a lot of (hopefully simple) questions regarding what is acceptable as per the NEC, as I've run into a few very difficult inspectors on job sites who, well, are difficult, and want to cover my bases in case the house is inspected (I work with low voltage controls, but work together with the job electrician depending on the job).
1) Breaker box (currently a fuse box, will be swapped out shortly by someone else) is mounted in the below grade basement, bolted to a sheet of plywood which is attached to the cinder wall. Top of breaker box will be approx 12" lower than the joists. Currently there is EMT taking the existing wiring to various junction boxes throughout the basement (all junction boxes are attached to the bottom of the joists, not tucked up in between). Junction boxes end in various spots, bushings let the wire out and up through the walls. If the breaker box is not covered by drywall of any sort, the wire needs to be protected in some form, correct? Meaning conduit/armor clad cable up to the joists at least, correct?
2) Hypothetically, could I run armor clad cable up in between the joists to a junction box, make a joint, and run romex from the joint throughout the joists onwards/upwards? Unsure of the NECs opinion on when joints are acceptable.
3) From what I gather it is acceptable to run romex through holes in joists *above* the floor you are on (if you're in the basement, then through the joists on the floor of the first floor). In the attic, two conductor is ran through the joists in the floor of the attic (half of the attic has a floor, the other has bare joists, easy to see). I would assume this is acceptable, but again, technicalities have bit me before. Plus I'd rather not drill holes through the structural beams that comprise the roof.
I've got most of the rest sorted out...GFCIs in kitchen/basement/garage, TR outlets throughout the rest, THWN cable in the basement/to the garage, etc etc.
Thanks!
Thanks!
