I have a switch that controls an outlet (only the top half) the other half is always hot. I would like to ultimately make the outlet constantly hot and use the switch to control a ceiling fan. I would also like to add another switch for the light kit separate from controlling the fan. I have access to the room from above and can drop down any new wiring. Is it OK to bypass the switch for the wall plug and then spice two new leads for the two switches for the fan and light all at the existing switch position? inside the switch there are 2 wires one has a black, white, and ground, the other has a black white, red and ground.
