I have a Dayton model 4k141B 1/2 hp 115/230 single phase motor, and want to wire it to a 3 position toggle switch to reverse direction. My electrical knowledge is vary limited, example I can change a light bulb. There are 7 leads coming out of the motor. P1=ungr-0 line: P2, T8, T3 say Tape low volt, and T2, T5, T4 say line conn. There is a note on motor which states, change T5 & T8 for CCW rotation. I have a 9 pole switch which says 10A 250vac, 15A 125vac, 3/4 hp 125-250vac, 1,2,3, phase on it. Also have two six pole switches one reads 10A 277vac,20A 125vac, 11/2hp 125-250, with numbers E60272 and LR39145 on it. The other 6 pole switch reads KEDU HY29D, 2hp 125-277v, 20/15A 125/277v, 18(12)A 250v-5E4, with a number on it 01E0907. First which switch would I use, and second which leads go to what poles, in other words, how do I wire a toggle switch to reverse direction on this motor.
This motor if I can use it will replace another weak 1/2 hp motor to run a winch to pull a dolly with a pontoon boat from our lake. The old motor has only 6 leads out of it and uses a 9 pole switch.
Thank you for any help and suggestions.
Cutty
Cutty
