That old intercom most likely used 18g or smaller wire.
1.5A through that small of a wire any kind of distance is most likely going to have way too much voltage drop.
Look at the wire...if it's 16g or larger, you might be ok...but if it's 18g or smaller....I think you will have issues with voltage.
Worse case....try it....go to the outlet that is the longest distance from your power source....and do a temp hook up....measure the voltage....with the unit plugged in, if you above 4.75v...I guess you will be ok....maybe.....if the lines are daisy chained....then I see more issues....
