greetings.
I had a contractor relocate my attic air handler, supply and return ductwork and some registers during my home renovation.
The hvac contractor relocated a return grill in the 2nd floor hall, which was great. He also utilized an existing return shaft that goes to my 1st floor, but he had to connect this return shaft to the relocated air handler. Long story short, the return flex leaves the air handler and penetrates the subfloor near the air handler, in the bay that leads to the return shaft. However, there is nothing connecting the flex pipe to the return shaft - there is sheetrock, joists and an old plywood subfloor acting as my ductwork. There is a space of about 12 feet from the flexpipe to the shaft. The top of the shaft was covered with a piece of sheet metal nailed into the subfloor.
To me this seems just plain stupid and we spent a summer drawing hot, stale, dirty subfloor attic air into our system. I am going to try to get him back in, but in case he does not come back or in case I do not want him back, do you think there enough room to add ductwork and insulate under the subfloor to close the circuit? - 2x8 joists.
:jester:
:furious:
:jester:
