Evening all.. I'm getting conflicting info regarding my AC. I'm planning on adding Central Air / Heat (unit in my attic), I have a split level home with 5 bedrooms on the "top" level all off a long hallway. I have had some people say you need a return in every room (except bathrooms) to have a balanced system all within a degree of each other then some other AC guys have said, no, one large return in hallway is fine, even when the bedroom doors are shut you'll be good. THOUGHTS?
I know it's more work to run ducts to each room, hence maybe a little more expensive, but two reputable companies told me the opposite and i'm concerned.
