1 - 2 of 2 Posts
I have a HVAC system with two return air grilles, the filter is located under the unit which is in a wall cabinet. I would like to replace the grilles with the types of grills that accept filters, can I do this without worrying about air flow restriction? If I do this, can I remove the main filter under the unit?
Thanks!
· In Loving Memory
What size system is it.
What size are the holes in the walls.
When the air filter is in the grille. The grille usually needs to be bigger.
1 - 2 of 2 Posts
