I had a new HVAC system installed last year with I believe a 5 ton AC unit. The home is 2200sq ft. I have two return air ducts that are non-flex 10'' ducting. One is located pretty close to the unit, the other is way on the other end of the house. Both units whistle on and off when the AC or HEAT is on.
The AC does not cycle at all. It's almost impossible for it to cool the house it will just maintain the current temp.
Is my return ducting too small? How big should they be? Is 2 enough?
