What's up everyone.
I am finishing up digging out an old and falling retaining wall and getting ready to put a new one up. The wall will be going along one side of my driveway, the driveway slopes towards the house and has a drain at the bottom of it.
The block are 85lb interlocking block, no pins or mortar will be used. They are 12 inches wide. I believe that the wall will be 5 block high at it's highest point. I have a few questions:
1. how far back behind the block should be dug out for gravel? I am at around 2 ft right now, which will leave 1 ft for gravel behind the block.
2. I was not planning on putting in a french drain or weep hole. I figured since the block are interlocking that they will get enough weepage through them. Am I correct on this thinking?
3. how deep should the gravel bed be underneath the 1st course of block be? I was thinking 3-4" should be plenty. Is sand needed?
4. how deep into the ground should the first course be? I was thinking 6-8 inches. Is this enough? too much?
5. Should I use landscaping fabric between the gravel and the dirt/clay?
Thanks
Thanks
