Disclaimer: The extent of my HVAC knowledge goes as far as changing the mercury thermostat for a programmable model. I have done that twice. Other than that, I know not much else.
I called a local HVAC company to have the yearly inspection done, and to diagnose an issue with my condenser.
I have noticed that my condenser would cycle off, then right back on soon after starting up. It would only do it once each time then appear to run fine afterwards. I suspected that it was low on refrigerant, but honestly had no clue.
The guy shows up, tells me what he's here for, and I ask if he minds if I watch so I can better familiarize myself with everything. He was fine with me watching, and explained everything as he went along.
He confirmed that the condenser was low on refrigerant and we found the leak in the evaporator coil. The evap coil was replaced less than 10yrs ago (long before I lived here), but was improperly installed. The evap coil was installed at an angle where it would hold water and was rusting out. I saw the water and the rust. I saw him confirm the leak with a detector.
He then called a number on speakerphone to verify the warranty on the evap coil. The previous owners never registered the evap coil, and because of that, it only had a 5yr warranty. It's 5yrs too late for that now. I need to buy a new evap coil. He said that he could have the new one in a day or two.
My outside condenser is from 1996. This he confirmed both by explaining the serial number to me, as well as calling it in on speaker phone. He pointed a code violation to me. The breaker panel is more than 15ft from the condenser and is around the corner from it. There is no shut off at the condenser. He also noted that the sight glass was also installed on the wrong side of the filter drier and was not accurate.
He told me that if I put a new evap coil in, they will use R22 since that is what my system already has in it. If I just go with the evap coil and my condenser breaks in the future, then it will cost more to replace the condenser than if I were to replace it now, because you cannot get a condenser for R22 anymore, and the the evap coil would have to be changed again because you cannot mix R22 with the new stuff. He said they can blow out the line and reuse that. Does that sound right?
Considering the age and appearance of my condenser, I had already considered looking into having it replaced for peace of mind before I called this company.
So, new Evap Coil and condensor.
My current condenser is a 3ton. When I was buying the house, the inspector told me that the AC was undersized for this houses size. 1800sq ft. I have one single 20x20 air filter that I think flows 800CFM. Without ever mentioning this to the HVAC guy, he told me the same thing.
He gave me a list of prices and specs of new condensers. He said that a 4ton would do much better than what I have now. I chose to go with the American Standard 4A7A40 Series.
From there, we moved on to the furnace. My blower is rated for 5 amps and is drawing 7.5. He swapped out the capacitor and showed me that with a new capacitor it was now drawing 6.3 amps. Still more than it was rated for. He said that my capacitor was at half life, but the blower motor would need replacing in the near future.
He pointed out that my furnace did not meet code. It was sitting on wooden blocks. The spacing where the flue pipe goes through the roof only had a half inch of room between the flue pipe and wood roof sheathing.
We tested the manifold? I cannot remember the name. It's the part of the gas furnace where you see all of the flames. He showed me that there was one spot that was making a constant flickering small orange flame, where all of the rest were blue. He said that it could have a tiny pinhole in it allowing oxygen in. Otherwise, everything else looked ok. The furnace and blower are from 1983, original to the house.
I asked what it would cost to replace the blower if it were to go out, and I asked the cost to replace the entire furnace which included a new blower. Considering the age of my HVAC system, I am more interested in reliability than a cheap fix and not knowing the next time it may break.
So. I will be getting a new Evap coil, condenser, and furnace. We measured the attic opening and both the new and old units will fit through there.
They will fix everything that does not meet code, which included putting a shutoff switch at the new condenser, removing some of the sheathing to clear the flue pipe, and putting the new furnace on metal stands.
They will install a media filter in the attic, as well as add another 20x20 air filter in the wall above the existing one.
They will also throw in a free Honeywell Pro 6000, even though my current programmable Tstat works fine.
There will be a 10yr warranty on the Condenser, Compressor, Evaporator, and related parts. A 20yr warranty on the Heat Exchanger. A 2yr warranty on labor.
They will be back Monday to do all of the work, and said that it will all be completed the same day. Total cost is $7,805.00.
Is there anything else I am missing, or should do in preparation? Does everything I posted sound about right?
