I know there are numerous threads covering this topic but maybe my situation is different. So, paying no mind to the toilet flange during my tile installation the flange now sits a little less than 3/8" below the finished tile floor, whereas it was nearly flush with the old lauan and vinyl combo. The flange is screwed directly to the wood sub-floor. The toilet has a "stub" on it, maybe 4" long that would sit inside the flange hole. There was no wax ring around the flange. Can I simply just put the toilet back since the stub on the toilet will sit well inside the flange or do I need to add a wax ring, flange extender, or both, or......?
Also, in case my tile is not perfectly flat and level, are there shims or something of the sort to stabalize the bowl? Thanks in advance!
