Hello All,
I am designing and building a 400 sqft deck. In pouring the footings, I made a mistake in that the footings are level with grade. The total height of the deck is 21 inch and the footing is a 2x2 by 18 inch deep.
I realized that I need to raise the footing by 2 inch or so only later by which time it was too late. I have also inserted the J bolt.
The problem I now have is when it rains, the water puddles around the J bolt and the post base. Even though the bolt and the base are galvanized, my feeling is that eventually they will corrode and cause trouble,
How do I fix this problem ? Cauking, pour more concrete and build a pyramid around the post base ?
I am trying to think up with all kinds of solutions.
Other idea that I was thinking of was to lay pressure treated plywood over the joist instead of regular deck planks and then install the VIFAH deck tiles on top of the plywood. I was thinking 3/4 inch pressure treated plywood. This will keep most of the water away from under the deck. Is this a good idea ?
Please help !! I have finished framing and need to take one route or the other to finish the deck.
thanks
thanks
