Thanks - I'll try it this weekend (I have a Mason on standby in case this goes south) . Here are 3 more questions:
1). How much of a window of good weather do I need before I start putting in mortar?
2). In places where the space is very narrow between the cement pad and the brick would you grind out anything to make space or just do your best to put some mortar in there.
3). I read alot about the best type of mortar to use on this kind of job. The house is 50 years old. Can I just purchase a mortar mix from HD or Lowes? There is a store near me (National Lumber) that builders more frequently visit. Im not sure I trust the people at HD to steer me right.
1) The brick should be at least 40 degrees when tuckpointing. Use hot water to aid in the mortar set. Mort shouldn't be allowed to freeze for a doy or 2. It should be small enough to cover with an old blanket or the like.
2) Definately grind 3/8" to 1/2" wide minimum if you don't want to patch every year.
3) I personally mix my mort for a project like this from scratch, but I have a shop full of different types. I also ude as much Portland cement as possible, minimum of lime for workability & to control water bleed-out. In your case, for a small amount of mortar needed, I would try this:
1 - 80 bag of Quikrete Type S Mason Mix. (green, yellow, white bag)
1 - 80 bag of mason sand. (not silica)
20-30 pounds of Portland Cement.
6 ounces Bonding Agent (make sure it says Admixture)
You should be able to get all this at a big box store.
