1 - 2 of 2 Posts
Have this separation between the two types of stone. I’m guessing chisel out the area then just repoint it? What type of mortar should I use to match that up? I’m guessing just mix up some mortar then just use a tuck pointer? I’m really worried about matching the existing mortar
639847
Have this separation between the two types of stone. I’m guessing chisel out the area then just repoint it? What type of mortar should I use to match that up? I’m guessing just mix up some mortar then just use a tuck pointer? I’m really worried about matching the existing mortar View attachment 639847
I really don't see a problem with the mortar joints I do see a crack.
The following may help you select a good replacement mortar if needed also looks like it may be a type "N" Tiger Lime 2.jpg
1 - 2 of 2 Posts
