Had a few questions on pex, hoping a few of you guys with experience can shed some light.
I'm planning on updating some of my 1st floor plumbing that is accessible from the basement overhead. Pretty much just going to follow the trunk and branch system that is currently there and replace the old piping in nearly the same configuration. 3/4" trunk and 1/2" branching is what I'm replacing with pex. The house isn't configured well to adapt a manifold so i'm sticking with the trunk and branch.
90 degree bend vs. a brass elbow fitting
I have a few places where I can probably get away with a bend instead of cutting in an elbow fitting. I know too many elbow's will slow down the water flow, but was curious is there is a rule on how many elbow's are ok. I can use the bend supports in a lot of places, but I think it will install nicer and cleaner in some places if I just use an elbow fitting. I know the name of the game is less connections leave less points of failure. What is a common rule to follow?
Straight run pex tubing and expansion
I saw that lots of plumbers use straight run pex since it is a cleaner stall compared to the rolls that want to keep the shape of the coil and bend. I like the idea of straight runs so it keeps the install clean, but I know that pex needs some slack for expansion. In the past when using coil pex I've left a little slack in-between the tube supports, or added a bit of slack. How do you go about leaving slack in the line for expansion with straight run pex tubing?
Where to install shut off valves
Right now the old plumbing has valves all over the place in the basement piping, but not many upstairs below the cabinets. Is it common to install less valves in the main basement piping and then install valves underneath the sink in the cabinet? Or should I put valve's downstairs to allow isolation, and also upstairs in case I need to shut the water off quick from underneath a sink in the cabinet? Probably makes sense to install them upstairs under the sinks, and in the basement piping, but I was curious what is common.
