Recently there has been quite a bit of condensation inside the back room windows of my home in the mornings. The trim around the glass is pretty rotten outside, and I'm assuming the inside is looking pretty bad as well (just can't see it quite yet). I've been searching around here to see if I can find a similar case, and so far I've found some good info, but wanted to get more opinions on how to tackle this problem.
My question is: should/can I remove this inner, 1" (I think) piece of trim, wood putty some of the really bad spots, run silicone around the perimeter, then replace the trim with a synthetic/plastic piece? So far, this seems like the best method to ensure moisture stays out, and it will hopefully prevent future rot. I'd like to replace it on both the interior and exterior.
Here are some pictures of the damage, and I've outlined the area where I'm wanting to replace.
Thanks!
Thanks!
