After some research, I guess I have an idea on how to replace a rotten base on my porch column. However, still have a few questions:
01. Would I have to remove the column completely in order to replace the base or could I just lift the porch ceiling enough to remove and slide a new base in?
02. How is the base attached to the column and the porch? Construction adhesive? Or is there a screw or nail to prevent it from shifting in case of some lateral force?
03. I saw there are plastic sleeves that will give the aesthetics of a base, would that be a better option?
Thanks
Thanks
