My old outlet decided to melt out of nowhere and I am replacing it with a GFCI. The GFCI is correctly wired and now providing power to the room fine.
In this electrical box, there are 2 load cables which also have a red wire, which I believe previously were joined with a twist connector and then plugged into the old outlet. They were used to make the bottom outlet able to be turned off by a wall outlet.
My question is, where should they be plugged into on the GFCI? The line neutral, load neutral, or load hot?
Thanks
Thanks
