I'm looking at replacing our original builder grade vinyl windows with stucco walls. Do I need to remove the exterior stucco up to the flange and remove it in once piece? Or should I leave the existing frame and use a replacement with a flush flange that will cover where the stucco currently meets the window? I found
but the existing windows are aluminum. Will this still work if existing windows are vinyl?
