I need to replace an old wooden door in a cinder block wall, but I"m not 100% how to go about it. The opening is 49 3/4" wide at the most narrow point and the height is 77 3/8" at it's lowest point. (I have pictures, but I can't get them off my phone.. hopefully I won't need them)
When I pulled the trim off, there's no buck attached to the block. The door jamb is about an inch thick and is attached right to the block. Given the measurements I provided above, is this a fairly standard opening, or an oddball size? If it is standard, what's the best way to go about ordering a door and replacing it? Thanks!
