I'm moving the disconnect for my heat pump from on my deck ledger board to in my crawl space. I have already taken it apart which is how I found out it was for the heat pump, so we have no downstairs AC!
In the box I have, at the bottom the ground wire from the power connected to a little metal strip at the bottom of the box. On the other end of the strip was a copper braid which was connected to the ground wire running to the heat pump. Everything is rusted so I'm replacing the whole box.
Will a new disconnect have a similar ground setup? Do I need to connect the disconnect box to a ground somehow? If so, how? Also, any type in particular of disconnect to buy? Wasn't sure if there were different types based on load etc.
Thanks so much!
Thanks so much!
