Hey all! This is my first post. My wife and I recently put a bid in on our first house. It's almost 1700 sq ft, 4 bedrooms and 2 baths, built in 1970. In ground pool out back, big tree out front, nice green grass front yard, long driveway, and a storage shed.
If our offer on the home is accepted there are a few things we want to do to the house. The previous owner closed in the 2 car garage and halfway converted it into a sort of living room/family room. A layer of carpet on a bare concrete floor and the garage door is just 'closed' with no opener attached to it. We will want to finish the conversion off right by removing the garage door and replacing it with a wall containing a door and/or window. We are considering either a french door or a double paned sliding glass door with the blinds built between the panes. I don't have specific measurements as of yet, but let's assume the garage door is 16'x8' for discussions sake.
My experience with wood is minimal. I'm more of a car guy, but am pretty handy and with enough research I don't find many tasks beyond my ability. So far, I understand I need a sill and top plate, studs at 16" on-center, cripplers offcenter over/under doors/windows, and offset fire breaks halfway up the wall between the studs. The code for Jacksonville, to my knowledge, requires fire breaks for walls over 8'1" but I figure it couldn't hurt.
So here are my questions:
1.Normally, you'd put a header above your door/window to take the weight of the structure above it whether load bearing or not. Since the header for the garage door will still be in place(the top plate will be fastened to it, in fact) just a few feet above any door/window I install do I still need to use a header for any doors/windows I put in or can I just make a frame of 2x4s and call it a day?
2. This deals with insulation. I looked at a map of the US earlier today and for my area it suggests R19 rating for my wall insulation. Using 2x4's for my studs, I understand that I can use either R13 or R15 in the fiberglass rolls or rigid foam which will range from just under R16 for EPS, around R20 for XPS, or around R25 for Polysio. The question is, using the more expensive product Polysio, would it be worth it considering I have no idea what the rest of the house is done in? Or should I take a light cover off and see what is used behind the rest of the walls and use that?
3. OSB vs. OSB Techshield sheathing. Is it worth it to use OSB Techshield over plain OSB for the exterior sheathing of the walls? I realize this doesn't 'improve' the R rating of the wall, but I understand it can help when radiant energy is hitting the wall.
4. Siding. I understand that I will need to re-do the siding on that particular wall. My options are to match the wall to the house or re-do the entire houses siding(Minus the front face, which is brick). It currently has 6" wood siding on 3 sides. If I do a wall at a time, is doing the entire house too big a job for just me? Also, is concrete siding worth it over wood?
5. To add to the siding question: if I choose to re-do the siding on the entire house would it be beneficial for me to rip off the sheathing as I go along and update the insulation and sheathing to better materials? Have the building materials changed much since 1970?
I want to thank you all in advance for your advice! Look forward to chatting with ya'll.
