The bottom rail of our garage door has some rot as we had problems with drainage (working on that). It is 5.5" x 1.5" x 16', and the bottom inch or two is rotted. I was thinking of replacing this board, since we can't afford a new door right now. I'm also repainting the door and replacing some small areas of rot with an epoxy filler, where the paint and caulk let some water in (you can see the corners of the panels in the picture).
Since the rails and stiles are all tongue and groove with each other and the particle board panels, I think replacing the whole board would be difficult since I don't have a router table or the bits to make the grooves and the profiles. My idea was to remove the board, rip it in half or so, and replace the bottom half with pvc board. I only see PVC boards in 3/4, so maybe I could sandwich 2 together? Then use some kind of metal piece on the back to join the PVC and the wood board. Plus a bunch of construction adhesive.
Will this work? Is there a better option I'm not thinking of? I know it might not look perfect, but at least it will get us through until we can get a new door, and with some filler and paint maybe it won't look too bad.
Will the PVC glue together well? Guessing theres something like pipe solvent that will weld it together.
Thanks!
Thanks!
