I have a shed that was converted into a small living space. It was built completely on the the ground, without PT joists. I am in the process of replacing the subfloor and joists. Should I dig out some of the soil and put a vapor barrier and gravel? My concern with this would be disturbing the rest of the structure if i start removing too much. Probably would need to removing at least 4inches of dirt to get enough gravel in and keep the joists off the soil. If I shouldnt remove a bunch of dirt is it possible to put the vapor barrier on the soil then rest the joist on 6x6 pavers every few feet just to keep them out of the ground and give it some support? The structure sits directly next to a canal and is grandfathered in so im not sure jacking the structure up would be feasible, and not sure I can get in to that....Thanks
