I want to replace the trim that runs flush to the windows and my porch ceiling. I would like to replace it with PVC trim. The house was built in 1963, it an all-brick ranch. After some research, I've read the PVC trim can be fastened with Cortex fasteners for better results. The original trim looks to be wood but the previous owner installed some sort of plastic channel on the edges and then soffit panels. If I remove everything, how should I fasten the PVC trim? Drilling the bricks and using anchors? Or is there a wooden framing behind it? Thanks.
