hi all - i have to swap out the expansion tank on my hot water heater. i'm a first timer on this project, but after watching some videos it seems pretty simple. the question i have however is about matching the pressure in the tank to the water pressure. I have not been able to locate a pressure gauge on the water line, so i really don't know what the pressure is. it is possible that the pressure gauge is up in the basement ceiling, which has been sheet rocked over.
i am assuming that i won't be able to use the old expansion tank as a guide b/c the bladder is likely busted, which is why i am replacing to begin with.
any thoughts here? should i go toward the top of the pressure range? the bottom? right in the middle?
thanks
thanks
