1 - 7 of 7 Posts
Plant Window Building Wood Twig
Fixture Wood Floor Wood stain Hardwood
Window Wood Interior design Fixture Wood stain
Property Window Fixture Wood Rectangle
Wood Floor Flooring Tints and shades Fixture
Wood Composite material Tints and shades Rectangle Flooring
Wood Gas Automotive exterior Fixture Aluminium
Window Fixture Wood Composite material Building
Window Fixture Wood Composite material Rectangle
Wood Fixture Grey Rectangle Window
I'm remodeling our bathroom and we have a vinyl double hung replacement window that we'd like to replace with an insulated frosted window. A non opening single piece of glass that will allow the water to drain away easily. Previously we used a window shower curtain to keep the water out of window tracks.
This window looks to be held in with 4 screws through the side and a ton of caulking.
On the exterior, there looks to possibly be nailing tabs but can't tell with all the caulk.
Will I need to remove a lot of the siding, or just the J channel?
My main concern is keeping it water tight on the outside. Will I need to get ice and water shield in there around the frame?
You'll likely have to remove the siding, J- channel, and flashing in order to remove the window. If you're getting a permit for the work keep in mind that a window within 60" of a tub or shower needs tempered glass.
1 - 7 of 7 Posts
