1 - 8 of 8 Posts
I want to replace a cord end(120V grounded). The ground is marked green but the hot and neutral are both black. How can I determine which is which since there is no power running through? The other end is not accessible.
Discussion Starter #3
Block heater. One of the jacket ribs has white writing on it but I cannot make it out as it's severely faded from weather.
Master General ReEngineer
Ayuh,... 1 of te leads should have a raised ridge on it, that's the neutral....
The Hot lead will be smooth all the way around...
Discussion Starter #5
Both sides look the same. Only difference is the white writing. Internally the strands are the same color and thickness as well.
Ayuh,.. In that case, It don't matter...
It's just a straight through resistence element anyways...
Mad Scientist
The marked wire is the neutral, whether the marking is a raised ridge, ribbing, or writing. So in your case, the wire with the white writing should be the neutral. That said, Bondo's right, it probably doesn't really matter with a block heater, but you might as well hook it up the right way if you can.
Discussion Starter #8
Thanks guys, you're right. I was able to scrap off some crud and made out some of the writing which said "NEUTRAL WIRE" on the jacket.
1 - 8 of 8 Posts
