1 - 18 of 18 Posts
I bought a replacement motor for my armstrong hvac, the old motor has three wires and the new one has four. I was told that on the new motor I dint need to use the brown/white stripe wire and to just us same color to color, problem is now the thermostat doesnt have a display. What to do? Thanks Rick.
Administrator
Check to make sure the blower panel door is on right. Also make sure you didn't knock any other wires off while you were changing the blower motor.
Ok, Im still at a stand still. I have the old motor with three wires, (brn that went to the F on the cap, purple that went to the C on the cap, and the blk that went to a board). The new motor has four wires brn, brn/wht, yellow, blk. My cap has three poles/heads. What goes where, I thought this would be pretty easy, I dont know if im just getting to upset and not thinking it through all the way or just dumb. The guy at Locks where I bought the new motor said "tape the brn/wht, and hook blk to blk, brn to brn, and purple would be yellow?" Thanks for all the help. Rick
Discussion Starter · #9 ·
If you have two tab on the F/C/Herm side of the cap, does it matter which one you hook it to? I know you cant hook your common to your fan, but if you have two for your fan like brn and brn/white.
I'm Your Huckleberry
Are you using only a new single run cap for the new motor which would look like this
or are you going back to the original dual run capacitor which looks like this
or oval such as
What software did you use to make this schematic?
I used google image dual run capacitor software. :)
I clicked on that image to get to the "full size image" link which I clicked on and it took me to photobucket where it was originally posted.
LOL :thumbup:
Administrator
Best to also replace the dual run capacitor. Also, wire nut and tape off th brn with white stripe wire.
If teh motor runs in the wrong rotation, just reverse the 2 wires from the motor on the capacitor.
1 - 18 of 18 Posts
