I just bought a house and it has cast iron sewer pipes. I want to replace it with pvc. All the pipes i want to replace are accessible and easy to get to from the basement. Do i just put pvc pipes where the cast iron is? Do i cut the cast iron near the start and end of pipe and attach pvc? If so, how do i connect the pvc to the cast iron? Should i use the same size pvc as the cast iron?
The pipes are in a relatively small space so i could put pictures up, but im not quite sure how to. If someone would be kind enough to respond to this and be able to help me, and explain how to add a picture it would be greatly appreciated!
Thank you!
Thank you!
