Hi all,
I recently discovered our kitchen drain is delivering our sink and dishwater water right into our crawl space (photo 1-3). The cast iron pipe that has corroded and broken off is also detached 14 feet later at the connection with the drain pipe (photo 3).
I've handled basic plumbing before in the kitchen and bathrooms, but this is a new and more intimidating endeavor. Right now I'm thinking I could cut square the cast iron kitchen pipe in photo #1 with a recip saw and connect it to a 2" Sch40 pvc pipe using shielded no-hub coupling. Then I can connect the other end of the new pvc pipe to the main pvc pipe drain using a standard 2" PVC coupling. What do y'all think?
Thanks!
-MK
Thanks!
-MK
