Hello,
I've been struggling with what to do with my garage door frame for the last couple of weeks. Let me give you some background.
I apologize for being wordy.
Garage:
Existing trim (removed due to damage and rot):
With that background, the caulking eventually failed ALL the way around the door and water made it through the caulk line as well as the crack in the J-channel. What ensued was the 1x2"s rotted completely and the 1x6"s started to rot. Thankfully the actual structural frame of the garage door is intact.
I have since removed all the rotted wood and am left with the bare structural wood of the garage.
My plan was do replace all of this with a brickmoulding and J-Channel like I see on vinyl sided garages all over the place.
My Concerns:
Any assistance is greatly appreciated. If you need clarification, let me know. I'll also try to get some pictures up shortly.
Thanks!
Garage:
- 2 car garage with single 16' door
- Aluminum siding with styrofoam backing
- Appear to be fiberboard behind the siding, there is no wrap
- About 1' of siding on one side of garage door and 4' of siding on the other
- Door was framed with 1x6" boards. These were perpendicular to the door.
- 1x2" boards were stacked to make a 2x2" border around the frame of the door, this faced outwards.
- Aluminum coil stock was bent in the shape of a "J" to cover the 1x6" and 2x2". It was then caulked along where it met the siding.
- 1" deep J-Channel was used along the top of the door frame to hold the aluminum siding above the door. Where 2 pieces met, there was a gap that was seemingly never sealed. The J-channel was caulked to the aluminum coil stock.
My Concerns:
- How do I address the J-channel going across the top of the door? I can't find any single piece that is long enough, so it would have to be spliced. I can't find anything that tells me how to do that with aluminum j-channel (is it different from vinyl?)
I'm assuming I will also need a drip cap under the J-channel, so I'm assuming I will run into the same issue of having to splice it along the top, but I think that can just be overlapped?
- How do I secure the j-channel along the sides without removing the siding? I'd like to avoid the possibility of damaging the siding since it has faded with age and replacement siding would mean residing the whole front of the garage.
- Say I do get J-channel installed along the side, and then put brickmoulding up against it, how do I stop water from getting between the two and causing damage there as well?
Thanks!
