I have a 28 year old house that was built with a vented fireplace. Being vented it obviously has chimney pipe. The house is a 2 story house so the pipe runs from the top of the chimney to above the second floor - about 24 feet.
We are doing some remodeling. I removed the sheetrock to add cement board so that we could tile the the wall around the chimney. We then decided that the fireplace was too old so we thought it would be a good idea to replace the fireplace. In replacing it we want to go with a ventless fireplace.
The problem that I see is the chimney. I don't have to replace the structure that surrounds the chimney, as it will give the house that external look of having a fireplace, but I don't know what should be done with the chimney. Obviously it will not need to connect to the new ventless fireplace. So do I need to do more tear-out work to remove the entire chimney, close up the location of the cap, or could I simply disconnect the chimney at the top of the fireplace and build a wood frame to hold the rest of the chimney in place over the ventless fireplace, then close the cap at the top, to prevent birds or other animals from crawling in a nesting, be acceptable.
Has anyone done something similar to this type of fireplace replacement work?
Hope this makes sense.
And thank you in advance for your time to read this and for your replies.
