I need to have switches at the top and bottom of my basement steps. Currently there is just a switch at the top, with power coming from the light. I want to install a second switch at the bottom, but I do not have access to the first switch to add an additional wire between them. Can I use the green ground wire in place of the red traveler wire and ground each of the original switch to the box? Do I have to have a ground wire on the switch if the light itself is grounded?
I tried to add an additional wire, but do not have wall access to do so.
Thanks you,
Chris
The green wire is unusual for residential wiring. Is this a conduit and wire system (Chicago)? If so, you can pull more wires in the existing conduit.
Make access or research wireless switching.
Anothe option would be to install a motion detector that would see you coming up or down.:thumbsup:
12 year IBEW member
go to home depot/ lowes they should have an add on three switch that is wireless the main switch would cover exsiting and the wirelss switch would go at the bottom.
