Hello,
I'm replacing an old mercury thermostat from 1959 that has three wires:
Red - 4
White - 5
Green - 6 / Y
Only the green wire was connected to a letter/number, the rest were just attached to numbers. This thermostat is connected to a boiler only that heats the house using baseboard heater.
Honeywell Home/Bldg Center RTH2300B1012 5/2-Day Programmable Thermostat.
I've connected the red to the R that is joined with RC. The White to W. Green to Y.
The problem I'm having now is that the heater will not turn off - I've tried to set the heater to 70, but it is at 77 and climbing...
I went down to the boiler room and noticed that the zone control valve is open when it should be shut....
Anyone have experience with these old thermostats and what my wiring should be?
Thank you,
Banzzy
Red - 4
White - 5
Green - 6 / Y
Thank you,
Banzzy
