Subject: Kitchen counter outlets, split GFCI
Topic Residential Outlets & Circuits
Category Kitchen Outlets & Circuits
Keywords kitchen,receptacle,outlet,gfci
Date Created 6/17/2004
Date Last Updated 7/4/2012
Question
I understand the Code requires GFCI (ground fault circuit interrupter) protection of receptacles next to my kitchen sink. Can I install a 15 amp GFCI type receptacle at these outlets?
Answer
No. The Code requires either a 5-15R split (15 amp multi-wire circuit with 15 amp split receptacles) or a 5-20R (20 amp circuit with T-slot) receptacles for kitchen counter outlets. A 15 amp rated GFCI receptacle cannot be installed in compliance with either of these requirements. Code compliant GFCI protection of the split circuit and receptacle option can be achieved by installing a 2 pole 15 amp GFCI circuit breaker at the panelboard. Code compliant GFCI protection for the 20 amp non-split circuit option can be achieved by either installing a 20 amp GFCI circuit breaker at the panelboard or by installing a T-slot GFCI type receptacle at the outlet.
Rules 26-700, 26-712, 26-722.
Ontario Electrical Safety Code 25th Edition/2012.
